Bad inj??
Old Jun 14, 2015 | 09:23 PM
happyhapka's Avatar
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
Bad inj??
1986 trans am LB9
already how's it going guys I have a problem running very very very rough wanting to die everything checks out good I checked out the ignition, replace the wires, replace the cap and rotor and the coil, no vacuum leaks, fuel pressure good,
but I did test the fuel injectors and I will write them down but I am not real sure what I am looking at I need to know rather I have a bad injector or injectors...
I ohms my injectors here is what they turned out to be
Cyl
1... 16.7
2... 17
3... 16.8
4... 16.7
5... 16.6
6... 16.8
7... 16.8
8... 16.7
Are these OK??
I read somewhere that they should be
16.0 +/- .5
Old Jun 15, 2015 | 10:18 AM
happyhapka's Avatar
Re: Bad inj??
Bump.
Old Jun 15, 2015 | 07:20 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Bad inj??
That's not really high ohms for stock. I'd worry more if one was really low, the coating on the injector coils get eaten away for ethanol and the resistance will read low. That doesn't mean they aren't clogged or leaking. If they're factory original it may help to change them anyway.
Old Jun 15, 2015 | 08:18 PM
southbay08's Avatar
Re: Bad inj??
Originally Posted by happyhapka
1986 trans am LB9
Cyl
1... 16.7
2... 17
3... 16.8
4... 16.7
5... 16.6
6... 16.8
7... 16.8
8... 16.7
Are these OK??
16.0 +/- .5
They are actually ok. Did you test them both hot and cold? If you have a noid light you can check to see if they are all pulsing.
KCG
Jun 24, 2020 04:33 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
gta892000
Sep 16, 2015 12:40 AM
