Fuel Lines
Old Dec 18, 2001 | 10:48 AM
SgtSkip's Avatar
Fuel Lines
Are the fuel lines from the tank to the fuel pump supposed to be metal on the fuel pump end? Mine have fuel hose between the end of the lines and the pump. There's been so many jury rigs on this car I'm not sure what's right and what's not.
Old Dec 18, 2001 | 11:04 AM
Guest
Guest
Posts: n/a
There are rubber hoses back there from the lines on the body to the lines on the fuel sending unit/hanger. I am pretty sure the pressure line has a fitting on both ends, and the return line and other lines are just clamped.
Old Dec 18, 2001 | 05:05 PM
SgtSkip's Avatar
Are you talking TPI or Carb? I have hoses on both lines from the tank on the fuel pump end by the engine...
Old Dec 19, 2001 | 01:04 AM
85 Berl's Avatar
Sgt. Skip, if you have a carb, there is supposed to be rubber line between the lines and the pump. It allows some flex when the engine moves while running. I think the rubber lines near the tank have the same purpose, but I don't know why the tank would move. Probably for removal/installation. If you remove the lines, I recommend replacing the cheesy stock spring clamps with real ones if it hasn't already been done.
Old Dec 19, 2001 | 02:41 AM
Guest
Guest
Posts: n/a
Yea, there I was thinking TPI again
Anyways, yea its all rubber hoses with clamps, and the factory clamps while they look odd, work well. Just dont reuse them.
Old Dec 19, 2001 | 09:26 AM
SgtSkip's Avatar
Good to go. Thanks guys!
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
