Don't know where these go
Old Jun 23, 2015 | 11:24 AM
RedIrocZZ's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 C.I.
One is yellow the other is red I was wondering where they go I just did a recent engine swap and I'm finishing up
Old Jun 23, 2015 | 12:00 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Don't know where these go
They plug onto your distributor cap* . The red one (Actually pink) is +12V key on power to the coil , and the other (should be white I thought ?) that you identify as yellow is the tach signal . If you look at the distributor cap , you'll see where they plug in .
* assuming you have the large cap setup with the ignition coil built into the cap . If you have the small cap setup with the separately mounted coil , then they go to the coil and not the cap ...
Old Jun 23, 2015 | 12:07 PM
RedIrocZZ's Avatar
Engine: 350 C.I.
Thanks you
Old Jun 23, 2015 | 12:14 PM
OrangeBird's Avatar
Car: 1989 Firebird
Your Welcome , and I hope all goes well with the engine swap .
LT1Formula
20
Nov 14, 2015 12:02 AM
db057
Sep 4, 2015 07:57 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
theshackle
Aug 23, 2015 03:49 PM
