Does color on valvespring signify anything?
Old Jun 24, 2015 | 10:23 PM
86ltrain's Avatar
Car: 1984 Z28 HO
Engine: 5.0
Just took my valve covers off...462624 "Hencho Mexico" heads, noticed my valve springs have a brown stripe on them. I thought I read somewhere that brown stripe signified "Z28" springs. I bought these heads as crate motor take offs and they are basically new / unused. Any ideas? I'm going to be running an XE 256 cam, not sure if I have to change springs. If I do, I can pitch the rotators and use std retainers on all 16 springs right?
Old Jun 25, 2015 | 08:17 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Does color on valvespring signify anything?
I've heard that, I've also read about them having orange stripes. If the heads are from Mexico I doubt the springs are true 'Z28 springs' but rather knock-offs.
Old Jun 25, 2015 | 11:49 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Color doesn't mean anything. The spring rate needs to match the camshaft recommendation. Stock springs are designed for stock camshafts unless a replacement cam is close to stock specs. The only way to know how good the springs are is to test the spring rate. They need to exert a specific pressure at a specific compressed height.
The stock springs will be fine with the XE256 cam
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
Linson
Oct 1, 2015 09:50 PM
Dragonsys
Sep 25, 2015 03:51 PM
