Throttle body issues
Old Jun 30, 2015 | 01:15 PM
Brianbajnuth's Avatar
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
I have a bbk throttle body and when I step in the gas pedal and release the throttle body is still open and I'm still maintains the sane speed or even more. But after 3-5 second of releasing the pedal the throttle starts to close slowly. What can be the problem here? Car is a 87 trans am
Old Jul 1, 2015 | 06:35 AM
ex-x-fire's Avatar
Re: Throttle body issues
Remove all the throttle/cruise/tv cables from the throttle body, is there any binding? Do the cables feel free? Maybe the cruise control servo is going bad.
Old Jul 1, 2015 | 12:04 PM
Engine: 5.7 350 TPI
I believe it only sticks when I am driving. It doesn't stuck when I'm in neutral free revving
Old Jul 1, 2015 | 01:59 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Sounds like you may need to adjust the blades open a little bit and then adjust the tps.
BBK throttle bodies are known for issues such as this.
Old Jul 1, 2015 | 03:17 PM
Engine: 5.7 350 TPI
Would that cause the car to keep accelerating when I let off the pedal for about 5 seconds?
Old Jul 1, 2015 | 07:15 PM
Car: 1990 Camaro RS
Yes it could, due to pressure differential on either side of the blade. Mine would do like you describe. It would also make the accelerator pedal somewhat stiff until you depressed enough for the blades to crack open. I adjusted the stop screw and then slotted my tps to get a good voltage. It's best to set with a scanner so you can see what the IAC steps are at.
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
