Oil leak - not sure how to trouble shoot
Old Jul 13, 2015 | 03:20 AM
KNIGHTE's Avatar
Car: 1985 TA http://bit.ly/1EadkbO
Engine: 5.0 V8 LG4 BBL
Transmission: 5 Speed Manual
hey guys
Here's a video of the leak after one hour sitting.
Any ideas what I should do? Can I use that fluid you can put in the oil to stop it?
Old Jul 14, 2015 | 08:52 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Oil leak - not sure how to trouble shoot
Degrease and wash it. When dry, start it up and look for the trail. Hard to tell in the video but it could be near the rear of the engine, leading to being the back of the intake manifold is leaking, valve cover(s) leaking or rear main leaking. Valve covers are the most common to leak.
Old Jul 14, 2015 | 11:29 AM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Looks like dripping down off the bellhousing and could be anywhere on back of engine. I would pull the bellhousing inspection cover and look at the flywheel. If a bad rear main seal oil would creep along the crank and into the bellhousing to cover the flywheel. If flywheel dry then its dripping down the back of engine and more likely the rear of intake or the vlv covers.
If u can clean up the engine like others mentioned u can try the old white flour trick. With a clean block u can toss white flour all over it and observe for leaks after running the car.
Old Jul 14, 2015 | 07:19 PM
Yup, clean it up first. Kinda hard to find an oil leak when it's buried under 6" of .... oil.
Likely suspects (hint: places to clean) include valve cover gaskets (clean the heads and other stuff right below them), intake "china wall", and oil pressure sending unit (clean under the distributor to spot both of those)
Old Jul 14, 2015 | 08:42 PM
mk1431's Avatar
Car: 89GTA Black, Black cloth
Engine: LB9 26,000 miles
Axle/Gears: 3.45 Australian 9 bolt
rear main leaking
Old Jul 15, 2015 | 11:05 AM
randy12v's Avatar
before you go pulling out an engine or dropping a transmission check the valve cover gaskets near the rear. and as previously said take off bell housing inspection plate and check in there. Check easy to access parts first (valve covers) followed by more difficult to check parts (oil pan gasket then rear main seal).
Hotrodboba400
Dec 10, 2019 07:07 PM
armybyrd
Dec 5, 2015 09:22 AM
tgp1990
Sep 4, 2015 06:24 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
