Ported my 3.1 heads, should get them flowbenched?
Old Dec 18, 2001 | 09:02 PM
3.1 firebird's Avatar
I am considering putting on my ported 3.1L heads, but I was concerned that I may have messed something up. Here's basically what I have done to the heads:
* Smoothed the valve guide bosses on intake and exhaust sides into tear drop shapes.
*Intake gasket match, I did'nt hollow out the entire port, just basically did the gasket match and smoothed it into the port about 1/4 to 1/2 of an inch.
*Smoothed the ridge just above the valve seat.
Thats basically it, I dont think I could have messed up to much as I was very careful not to reshape the countours of the ports, I basically smoothed them over.
I also plan on gettin .020 shaved off and slightly stiffer springs with a good valve job. I;m hoping this will all give me 8-12 hp when it is finished. The machinist worked on my heads when they were warped and did a very good job, all of the machine work will only cost me 150 total. By the time I get gaskets the total will only be around 200-220.
should I get them flowbenched to insure I didnt mess something p, or do you think I am ok? all input appreciated.
Old Dec 19, 2001 | 09:21 AM
89ROC's Avatar
If it doesn't cost too much, go ahead and get it done.
I thought you were going to sell that car..
Old Dec 19, 2001 | 10:41 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It's just a minor job; doesn't sound like you would've hurt yourself. If your car loses some performance, you might want to add an AFPR for extra fuel to compensate for the extra airflow.
Old Dec 19, 2001 | 01:14 PM
I was, but I have no job
I would like a 89-90 305 tpi 5 speed firebird with the GTA ground effects, but I cant find one that looks good since most of them are ragged out these days.
deracer
Apr 11, 2016 12:04 AM
italiano67
Aug 31, 2015 06:04 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
