can you use an edelbrock performer intake with a quadrajet???
Car: 1987 camaro
Engine: 305 V8 LG4
Transmission: 4-speed automatic
I've found a Edelbrock performer intake that needs cleaned up but good overall and was hoping I could use it on my 305 but will it work with my Rochester quadrajet?? Any help would be great. Thanks!
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: can you use an edelbrock performer intake with a quadrajet???
Works fine. Thats the current setup on my car.
Car: 1987 camaro
Engine: 305 V8 LG4
This is the one I'm looking at. Seems fine to me. Just looks like it needs a good cleaning
Car: 1988 Camaro
Is your engine 1987 (or newer) with center bolt valve covers?
If so that intake will not be a direct fit onto you heads/engine. You will need to elongate the 4 center intake bolt holes on that intake for the holes to match up
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
yes, a quadrajet works beautifully on a 2101 Performer intake.. which makes sense once you realize that Edelbrock designed it as an emissions legal intake that uses every other part that bolts to the intake manifold: you can even hook up the old style divorced choke setups or remove the blockoff plate and use the later hot air style chokes to make it a totally stock replacement part that frees up some power across the rpm band compared to pretty much any stock intake manifold.
Yup; Q-Jet bolts right up to it. That part works great.
That particular one won't fit your engine. It's for 86-back. The center 2 bolt holes on each side are at the wrong angle to fit your heads. (assuming they're stock to the car) You can slot them out and use angle washers; but as cheeeeeeep as the right intake would be, it's hardly worth it.
Car: 86 Camaro
theshackle
Sep 17, 2020 08:26 AM
86IROC112
Aug 17, 2015 02:00 PM
