Blue valve covers?
Old Aug 7, 2015 | 10:09 PM
mustangman65_79's Avatar
Car: 1989 Iroc
Blue valve covers?
When I bought the car, I was told that it had a 350. I looked up the car, and only a 305 is stock.
But the thing that gets me is, it has blue valve covers. Like ford blue. Is this stock? Or maybe is the motor out of another car/truck?
How can I find out what motor it has and if it is stock or not?
Old Aug 7, 2015 | 10:27 PM
Ty92Z's Avatar
Car: 1992 Z28 1991 RS
Engine: LB9 LO3
Transmission: 5 speeds
Re: Blue valve covers?
Look for your rpo codes and that will tell you what it was born with. Check the casting number on the back of the block and that will tell you what block you have. You can pull a valve cover and the casting number will tell you what heads you have. As far as the blue valve covers, I guess the previous owner wanted blue valve covers so he sprayed them blue.
Old Aug 7, 2015 | 10:56 PM
Car: 1989 Iroc
Code and vin both say 305
Found a pic here, that looks exactly like my car.
Old Aug 7, 2015 | 11:14 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Either he bought blue valve covers or he painted them himself, they won't tell you anything about what block is in it. As the others said, the casting number on the block is the best bet at knowing what size motor you have.
Old Aug 8, 2015 | 01:18 AM
Night rider327's Avatar
Car: 1988 Camaro
It's a valve cover... It comes off, can be swapped out, replaced, painted, etc. No they are not blue stock.
Chevy did use a light blue engine color in the late 70's though.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Gunsbee
Sep 7, 2015 07:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
