Designed cold air intake for carburetor models
Old Aug 15, 2015 | 11:35 AM
kyle5647's Avatar
Ok so I just made my own cold air intake, and I want to put a heat shield on it. I've tried making my own and it was alot harder than expected, so I decided to search the Internet for some heat shields I found a few that looked like they might fit but they look a little to big. My question is has anyone found a heat shield on the Web that can work with little or no fabrication?
Old Aug 15, 2015 | 11:56 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: Designed cold air intake for carburetor models
Make your own out of thin alum. house roof flashing. This stuff will bend by hand, cuts easy, etc.
Something like this http://www.homedepot.com/p/Amerimax-...8310/100054269
You could add some 1"x 1" or 1" x 2" boards to the inside of it to give it more strength.. Just use sheet metal screws through the flashing and into the boards.
Or even use metal or plastic strips screwed to it for support
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
