Injector/fuel pump question
Old Sep 16, 2015 | 09:41 PM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
I have a ZZ383 in an 88 IROC that runs great. Talented local tuner and Holly Commander have the EFI working fabulous. During a final road tune the 30# injectors were at 115% of duty cycle with the stock fuel pump. With that said, IF i go to bigger injectors (I'm thinking 36#-42#), would I need to upgrade to a higher capacity fuel pump to go along with the injectors? Thanks
Old Sep 17, 2015 | 01:00 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Injector/fuel pump question
115% duty cycle? http://injector-rehab.com/shop/idc.html
Old Sep 17, 2015 | 01:06 PM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
You are correct. Mine is a calculated number of injector open time versus rpm.
Old Sep 17, 2015 | 02:08 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
I would Eliminate the tiny FP coupler. Install 3/8 aluminum line flare and install a union coupler in it's place. Flare the other end. install a sockfilter. Upgrade to a external AEM fuel pump & lines, to -AN fittings.
Old Sep 17, 2015 | 02:19 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Put a 255 pump in! It may be the pump and not the injectors
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
