factory bracket for powersteering?
Old Sep 25, 2015 | 09:05 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
I've been looking for a quick easy solution to mount my power steering since I've removed the ac and I've seen many people have used this peice that bolts to the head. I've searched the local junkyard and I've never seen one. Anyone know if it's a factory peice and what vehicles it would come on?
Old Sep 25, 2015 | 11:24 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: factory bracket for powersteering?
It's factory - I'm a little surprised that you don't remember........
PARTS WANTED :
https://www.thirdgen.org/forums/engi...acket-non.html
Originally Posted by armybyrd
Happen to know if this will work with headers? Was thinking I could cut the part where the header would bolt to off if I had to.
Hi Again, ( what was your name ? )
Yup', it's the small V-Belt bracket used with non-AC power Steering Pumps. I also have the diagram showing how the factory set-up was assembled. Here are a couple pics I took this afternoon:
Here's the diagram:
** Make note of the spacer (#6). Because the AC bracket that normally mounts to the top/front of the pass head is usually removed during an AC delete,.... you must use a spacer in that spot to keep the pulley/belt properly aligned. I don't recall the exact thinckness - it's about as thick as any 2 factory V-Belt brackets.
( check out this AC Power system pic for comparison:
Could I get a few pics of the bracket? xxx xxx xxxx
Just to be sure this is for an older 350 with v belt setup that I removed the ac so I need a bracket that allows me to mount the pump without using the old ac brackets.
-thanks
Zip code is 80906
Old Oct 1, 2015 | 08:24 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
pics of a new bracket, post # 16:
https://www.thirdgen.org/forums/hist...te-1987-a.html
Old Sep 28, 2023 | 12:16 AM
MMiller1050's Avatar
I am in need of this upper bracket for non a\c cars. If anyone has one and wants to sell it please message me or email to:
mmiller6785@united.net
I have it as GM part number 469560 or 14101199
Thank you
Need this bracket
neilcase
Feb 12, 2022 07:09 PM
Xophertony
Aug 4, 2006 11:11 PM
4RCEPWRD
Jun 21, 2006 04:42 PM
cerice
Jun 24, 2003 07:54 AM
clemsparks
Sep 25, 2001 08:46 AM
