Help! 91 Camaro cranks but wont start
Old Oct 7, 2015 | 10:09 AM
charlie1011's Avatar
Car: 1991 camaro rs
Engine: 305 T.B.I
I have a 91 camaro with a 305 tbi, I've been having tons of problems recently with the car running rough and dying on me at low rpms. Here are the parts I changed with no improvement on the car.
EGR Valve
IAC
MAP Sensor
Coolant Temperature sensor
Sparks/Wires
Pickup coil/module
Rotor/Distributor cap.
Injectors
ECM - Probably going to return cause it made no difference.
Tested the fuel pressure and got the recommend 9-13 psi, getting spark and fuel. I'm out of ideas, what do you guys recommend?
Old Oct 7, 2015 | 06:48 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: Help! 91 Camaro cranks but wont start
Check for vacuum leaks!
Check your TPS also.
Old Oct 7, 2015 | 11:23 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Ohm your injectors, should run about 1.3. Check the injector spray pattern, should conical and even. Rebuild your throttle body, FPR may be ruptured. Check your timing. Good luck.
Old Oct 9, 2015 | 04:48 AM
Car: 1991 camaro rs
Engine: 305 T.B.I
I checked for vacuum leaks, I may replace the hoses just to be sure.
I replaced the TPS as well. As for the the ohms on the injectors, I checked those and they were fine. I rebuilt the throttle body and put new gaskets and a new FPR. Timing was just recently done as well.
Any other ideas? Hahah
Old Oct 11, 2015 | 07:19 AM
Johnny Gun's Avatar
Car: '88 GTA
Engine: 355 SBC, AFR 195 heads, Stealth Ram
Check for vacuum leaks again. While the engine is running, spray a small amount of starter fluid around all the hoses and intake gaskets and see if your rpms rise. Just don't spray any on your exhaust.
Old Oct 11, 2015 | 02:26 PM
antares57's Avatar
Did you disconnect the EST wire to set your initial timing? Also might want to consider having your ICM checked, didn't see it as one on the items replaced.
tommy z-28
Oct 6, 2015 10:58 PM
amcnellis
Sep 16, 2015 04:16 PM
Joniz
Sep 13, 2015 01:28 AM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
