Low Fuel Pressure
Old Nov 3, 2015 | 11:09 AM
rode1951's Avatar
Car: 84 Camaro
Engine: 632 hp 434
Axle/Gears: 3.90
Low Fuel Pressure
I have an 89 2.8. One day it runs fine, the next day it coughs, and sputters, and will barley do 30 mph, the next day it runs fine again. Sometimes it stalls, and won't restart. Sometimes it's hard to start, the next day it starts right up. Also, it's 20 psi low on fuel pressure. It runs about 26-27 with the engine running, then drops to 11 when I turn the key off. I've been told it should have 47psi. I've gone through everything. I've replaced the fuel pump (twice), the filter, the pressure valve, the fuel pump relay, the mass airflow sensor, and the injectors. I am at a complete loss, and need help.
Also, the injectors I put in were reconditioned ones. They measured about 3-4 more ohms than they were supposed to, but they read exactly the same as the old ones, so I put them in. Checking with a stethoscope, they seem to be working just fine.
Help! Help! Help!
Old Nov 5, 2015 | 02:45 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: Low Fuel Pressure
1st check your voltage @ the Pump harness connector.
are you sure your not leaking at the injectors- twisted O-ring
just because you replaced the Pump. Does not mean anything.
I have witnessed out of the box FP's fail. Or fail in 1 week. If your Fuel pressure is not above 38 PSI from the initial prime. you have a weak FP OR FP regulator leak, Inj O-rings leak.
Old Nov 6, 2015 | 12:47 AM
rode1951's Avatar
Car: 84 Camaro
Engine: 632 hp 434
Axle/Gears: 3.90
I'm getting full voltage, no twisted O-rings, replaced the fuel pump twice, besides some days it runs just fine. New pressure regulator
Old Nov 6, 2015 | 12:08 PM
88gta3508's Avatar
Engine: 231 / 383
2 options. Debris build up and Clogged. Weak pump.
Old Nov 6, 2015 | 05:28 PM
rode1951's Avatar
Car: 84 Camaro
Engine: 632 hp 434
Axle/Gears: 3.90
I've blown out the fuel lines, I've changed the filter for the second time. I'm thinking about changing the pump for the third time.
Tonyy_z
Oct 26, 2015 12:26 PM
rode1951
Oct 21, 2015 12:58 PM
gunznrosez87
Oct 14, 2015 11:56 PM
apie2546
Oct 14, 2015 03:33 PM
Poncho92
Oct 6, 2015 08:39 PM
