Question about AC controls.....
Old Dec 20, 2001 | 04:45 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Hey Guys, I was replacing the radio pod on my GTA, and I broke that little valve that has all the vacuum lines on on it that control (Max, Norm, Bi-level, Heat & defrost) for the AC. It was hissing when I shut the ac off. So I bought a brand new one from the dealer, it was $15. It is just a little round plastic piece with a rubber diaphram in it and the vacuum lines go to it. Well I put it in and it was fine for about a week. Now when I put the heat on it hisses for a while before stopping. Then once it stops it is fine. But if the car sits a while it hisses again for a bit and then is fine again. I checked it out and all the vac lines going to the part are fine and connected. Is it possible this part that I bought is defective?? I don't know what else it would be since I hear the hissing coming right from there. Any help would be appreciated. My controls are just the slide type, they are not digital.
Thanks!!
Mike
Old Dec 20, 2001 | 04:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The hissing is normal, that's the sound of vacuum moving through it to get to the little diaphragms.
You don't want a vacuum leak under your dash, that stuff is nasty. You have to use a special tool called a "vacuum cleaner" to get all the little piles of it up. And it's hazardous waste too, it has been conclusively proven that laboratory rats can only survive for a few seconds in an atmosphere of pure vacuum. At least it cures cancer though.
Old Dec 20, 2001 | 06:03 PM
Engine: ZZ4 - 350
LOL RB83 about that "Special tool". I know the hissing is normal for a few seconds, but not for a few minutes. When I step on the gas the hiss quiets down. It then eventually goes away. But if I shut the car off and come back to it about an hour or two later, it is hissing again. I never had any problems until I replaced the radio pod. Then I broke the valve piece. And when I bought the new Valve it was ok for about a week. Now it is hissing, and it is definitely coming from that valve. Could it be that Diaphram in the valve piece?? That is the only piece I can see being the problem.
Later
Mike
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
