this is a stupid question!!
Old Dec 20, 2001 | 01:08 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
can some one please explain to me what the liters mean like 5.0 or 5.7? I know this is stupid but i don't know.
Old Dec 20, 2001 | 01:18 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Metric equivalent of 305ci (cubic inch) and 350ci engines
5.0L (Liter) = 5000cc (cubic centimeters)
5.7L = 5700cc
And so forth.
Old Dec 20, 2001 | 01:35 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
And is also measuring displacement. Displacement is basically the total area of what the pistons occupy (bore), including travel (stroke), for each cylinder. Total displacement is including all cylinders.
I forget the exact formula, but there's one out there that will calculate the bore and stroke cubic inch area, then you multiply that by the number of cylinders to get your displacment (in cubic inches). You can then convert it over to metric cc's.
Old Dec 20, 2001 | 01:45 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Okay I have it:
( Bore (i.e. 4.000") x Stroke (i.e. 3.500) x 3.1416 (pI) ) x Cylinders (i.e. 8)
(4.000 x 3.500 x 3.1416) x 8 = 351.8592
First set calculates the total area of bore and stroke. Then multiply by number of cyls.
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
The equation is:
(pi * (bore/2)^2) * stroke * 8
It's just the equation for the volume of a cylinder (everyone think way back to geometry) where bore/2 is the radius and stroke is the height. Since you have an eight cylinder engine you multiply it by eight to get the total displacement.
EDIT: Allan, your equation is close but not exact. It's only going to work when (bore/2)^2 = bore.
Try your equation for the 305...
Old Dec 20, 2001 | 05:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
To expound:
By law, 1 inch = 2.54 centimeters.
2.54 centimeters cubed is 16.387064 cubic centimeters (or cc's). Since 1 cc = 1 ml, and 1000 ml = 1 liter, 305.19179 cubic inches (the displacement of a 3.736" x 3.48" GM 305 engine) times 16.387064 cc/cubic inch = 5001.1974 ml, or 5.0011974 liters, which is rounded to 5.0 liters.
Ain't math fun?
Old Dec 20, 2001 | 06:03 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Your formulas are right.
But here's the pocket size way of doing them.
bore * bore * .7854 * stroke = CID of ea. cylinder
Multiply by the # of cylinders = total CID
Then on a 'L to CID' and 'CID to L'
Divide CID by 61.4 to get ~L
Multiply L by 61.4 to get ~cid
These are only gonna be close, but you guys know how to round up or down right?
AJ
Cleotiz
Jan 6, 2018 08:56 PM
3.8TransAM
Sep 3, 2015 06:38 PM
masonta
Sep 1, 2015 06:40 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
