loud vibration humming
Old Nov 12, 2015 | 09:38 PM
wllmswynn's Avatar
car vibrates and/or hums loudly when foots on lights on gas, just cruising, between 40-50mph. if I let up of the gas it stops; if I press harder on the gas it stops.
any ideas?
Old Nov 13, 2015 | 11:01 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: loud vibration humming
this could be many components. balancer, internals. Diff, front end parts. you need to locate the Hum OR vibration. check you front end & diff for play. turn the engine off coast down a hill @ mentioned speed.
Old Nov 13, 2015 | 11:30 AM
wllmswynn's Avatar
Engine/ trans area
Old Nov 13, 2015 | 11:36 AM
88gta3508's Avatar
Engine: 231 / 383
slightly power brake the car. no wheel spin.. you will hear & feel if the trans mount is bad. Also check your drive shaft for play.
lt1z350
Wheels and Tires
32
Dec 1, 2015 03:19 PM
spoazzy1
Nov 15, 2015 12:12 AM
theking11863
Nov 14, 2015 06:23 AM
Jimmy2x
Nov 11, 2015 09:33 PM
Jacques101
Nov 8, 2015 04:43 PM
