How much HP do you think I have?
Old Nov 13, 2015 | 09:30 AM
David Fite's Avatar
Car: 1986 IROC-Z
I know it's hard to guess, but surely someone has a similar setup to give me an approximate number?
I'm looking at trading for a 92 RS next week. Here's the specs, I was wondering if you guys had a guess on the HP it might have...
305 block
IROC 350 heads/intake
Edelbrock open element a/c
Holley carb
new valves/roller rockers
aftermarket headers
aftermarket dual exhaust
PS>where and how much does it cost to get your car on a dyno? Never tried that before
Old Nov 13, 2015 | 10:30 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: How much HP do you think I have?
it's a open question. Mileage?? You need the Intake & carb "swap" Part numbers. Possibly other Parts. you are not aware of. Unknown tune..
Stock was about 170HP you now have slightly bigger valves. Face value. Plus OR Minus 30ish HP
do a online search for your area. you should find plenty of tune/Dyno shops. Roughly
$180.00 for a dyno pull
Old Nov 13, 2015 | 10:34 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
You dont mention cam or what 305 it started life as. Maybe 130-150 whp?
Old Nov 13, 2015 | 11:04 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
350 heads on a 305 block? Your compression is probably crap.
You are probably making less power than when it was stock.
Old Nov 13, 2015 | 11:22 AM
92g92's Avatar
Car: 1992 Camaro Z28
350 heads with a carbureted IROC intake? So an LG4 intake with lower compression? I'd say 150 whp, depending on condition.
rusty vango
Exterior Parts Wanted
Dec 18, 2015 08:14 PM
Fishy4Life
Oct 29, 2015 07:25 AM
transamaster
Oct 21, 2015 03:04 AM
rh76camaro
Exterior Parts for Sale
Oct 15, 2015 01:49 PM
Twin_Turbo
Oct 14, 2015 10:57 AM
