Name this piece please so I can buy
Old Nov 16, 2015 | 03:42 PM
Thomasm91's Avatar
I need the part that is orange and comes out of the heater hose connector. It's connected by a quick connect and has the 3 hoses on it but no one seems to know what's it's called so I can order a new one. Thanks in advance everyone.
Old Nov 16, 2015 | 03:49 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Re: Name this piece please so I can buy
Year?
Make?
Engine?
Old Nov 16, 2015 | 03:55 PM
Thomasm91's Avatar
Originally Posted by Formula 305
Year?
Make?
Engine?
Ah sorry. Got caught up in the middle or something. It's a 91 firebird and it's the 3.1l
Old Nov 16, 2015 | 05:23 PM
jharrison5's Avatar
Car: '87 IROC
Axle/Gears: 3.45 Posi
According to my book it is just called a "pipe #10115710" and is #51 in this diagram. It also says it's no longer available, but when it was it was on sale for $112.75. So more then likely it's going to be an ebay or junk yard find.
Old Nov 16, 2015 | 05:29 PM
Thomasm91's Avatar
Hey thanks. I really appreciate you taking the time to find that for me. Does anyone know of a piece that I could put there instead? Because like I said, that piece is leaking where it's connected to the heater hose connector.
Old Nov 16, 2015 | 06:14 PM
OrangeBird's Avatar
Car: 1989 Firebird
What I have seen done in the past is , the two little hoses go to a heater in the throttle body and can be eliminated (A lot of guys in the V6 forum do this as a mod when they're doing intake mods . It's said to keep the incoming air cooler) . Now if you eliminate the two little hoses , all you really have is one fitting that needs to be screwed into the manifold to bring hot coolant to the heater . If you search around the V6 forum for "throttle body heater delete" your likely to find threads better describing what they do and why (Mine's still in place since it hasn't rusted/leaked , so all I know is what I read about deleting it down in the V6 section) .
Good Luck with it
Old Nov 16, 2015 | 06:35 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Are you sure you need Part #51 (shown in the diagram) or Part #50?
Part #50 is available:
http://www.rockauto.com/catalog/x,ca...,parttype,6876
Old Nov 16, 2015 | 06:37 PM
Thomasm91's Avatar
Yeah I have that piece already that's number 50. And thanks on that info I'll look it up.
Old Nov 19, 2015 | 10:58 PM
Night rider327's Avatar
Car: 1988 Camaro
If you still need that part. I think I may have one for you. I just picked up a '91 camaro 3.1 L engine and trans today
Old Nov 20, 2015 | 01:14 AM
Thomasm91's Avatar
Thanks for the reply but actually the fix was really simple. Just took out the existing connection from the block to the heater bypass and then screwed a nipple in to the block and attached a 90 degree elbow and ran coolant hose to the heater bypass. Took less than 30 minutes from start to finish.
Old Nov 20, 2015 | 05:10 PM
Car: 1988 Camaro
Cool deal! Glad you got it fixed man.
Old Mar 6, 2016 | 11:44 PM
joe11's Avatar
sorry to reopen this forum but I have a 92 camaro rs and I'm in need of the actual name or where to find part 71 on the picture above. part #10088015 says its not available but the name is off I think, I cant find it anywhere on the 3.1l diagram
Old Mar 7, 2016 | 12:19 AM
Car: 1988 Camaro
#71 in the above picture is the Lower intake or intake base.. Do you need it for a 3.1L v6, 5.0L v8, or 5.7L v8?
I have a couple for the the 3.1 still
Old Mar 7, 2016 | 01:04 AM
joe11's Avatar
I need it for the 3.1l how much do you charge ?
Old Mar 7, 2016 | 01:46 AM
Car: 1988 Camaro
PM sent...
Old Aug 3, 2017 | 06:23 AM
FoxyAudy's Avatar
I'm looking for the same part for my 91 Firebird.
Old Sep 30, 2017 | 11:33 PM
kalim009's Avatar
Has anyone had any luck finding #71 from the diagram online? I'm having no luck....
Old Feb 17, 2022 | 12:08 PM
jianhuei's Avatar
I'm also looking for part# 10115710 Heater inlet pipe for 1987 Pontiac Firebird
The OEM was broken and need to get a replacement. If you have one for sell, please let me know. Thanks! -JH
Old Jan 1, 2025 | 08:04 PM
babyduck's Avatar
taking a chance you're still on here. What parts did you use to do this. Details
cowansauto
Sep 9, 2020 12:48 PM
68 RS/SS Ragtop
Feb 7, 2016 10:04 PM
soarestransam
Jan 7, 2016 08:02 PM
trackbird
Nov 25, 2015 01:44 PM
tattooedsails
Nov 11, 2015 06:20 AM
