Black Sooty Plugs
Old Nov 17, 2015 | 06:57 PM
roysatikas's Avatar
Car: 91 RS
Engine: 4 bolt 350, .060 over
Transmission: 700R-4
Black Sooty Plugs
Just a quick note of thanks to all the search results on Black Sooty Plugs.
HEI;
Ignition Control Module. DONE. Should be in some type of trouble shooting thread. 350 SBC,Summit Dist and the ICM deteriorated slowly over a few days or so. Did a 600 mile road trip, no probs running 3000rpm/80mph, returned home and had idle issues after I filled the tank (Premium) as the engine stalled at a stop light @ 1mi from getting fuel. Did the normal stuff: Heet/seafoam for possible bad gas, carb cleaner, removed IMS, metering rods, cleaned and blew out with air. Ran ok above 1500rpm but would not idle. Pulled the plugs, black sooty and full of fuel, checked the float adjustment, in limits. I had a DUI ICM, swapped out the Summit and the engine runs like a dream. (also swapped caps to see if I had a coil problem before ICM swap) This was frustrating but got it figured out from our Forums. The ICM can partially and intermittently fail allowing the engine to start and run and other times not start at all.
Roy
Old Nov 17, 2015 | 07:03 PM
roysatikas's Avatar
Car: 91 RS
Re: Black Sooty Plugs
Might be good to have an ICM handy like a fuse, I'm ordering another shortly
@ $40-$80 depending on what HEI you have how much power you want.
Roy
neely8
Nov 24, 2015 08:07 PM
gunznrosez87
Oct 14, 2015 11:56 PM
budowski
Carburetors
Oct 10, 2015 03:28 PM
Kuwait_Iroc
Oct 10, 2015 07:27 AM
aaron7
Interior Parts Wanted
Oct 6, 2015 10:49 AM
