91' RS 305, auto..please read
Old Dec 20, 2001 | 11:25 PM
CamaroEFI's Avatar
this is my second third gen and my first one was a SC w/o a tach so my question is how long does it normally take for the car to reach normal temp. after cold start, what RPMs should my car idle at, at what RPM's should my car shift gears at, and whats a normal RPM in OD w/ 2.73's..cruising at about 50-60mph.~~i was wondering all of this because my car takes for ever to reach about 2000RPM. Could the heat riser have anything to do with this (small hose that runs off exhaust manifold to intake)? Also, im pushing 3000-4000 in OD cruising down the road at about 55MPH. Is it my car or is my Tach. Wach? Thanks
Old Dec 20, 2001 | 11:55 PM
Joshua Leslie's Avatar
3-4000 at 50!
at 80mph in overdrive and lock up my car runs at about 1800rpm, with the 2.73s.
It takes about 10 minits for my car to fully heat up, but in the summer only about 3-4.
Is your tranny slipping?
Old Dec 21, 2001 | 08:51 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
If your car doesnt feel like its reving that high at 55mph then your tach could be off. Mine is off by 500 rpm at 3000. At 3000 rpm mine is actually running 2450. My car with 3.42 gears runs 75mph at the actual 2450.
Jake_92RS
Jan 28, 2020 10:37 PM
LittleFranks
Sep 17, 2015 12:22 PM
gta90
Sep 15, 2015 04:00 PM
michealleger
Aug 26, 2015 03:29 PM
GouldyGTR
Aug 21, 2015 10:43 PM
