Airtex MAF doesn't look like the Bosch unit on the car..did I get the wrong one?
Old Dec 6, 2015 | 03:24 PM
mdtoren's Avatar
Car: 1986 Iroc Z28
Hello!
I just got a new MAF from rockauto AIRTEX / WELLS 5S2640, opened it up and the internals are completely different from the Bosch that was on it. The thin wires are replaced with a circuit board and a couple fins that I assume sense the flow...did I get the wrong unit or is this the new tech version?
Old Dec 6, 2015 | 03:39 PM
Vader's Avatar
Re: Airtex MAF doesn't look like the Bosch unit on the car..did I get the wrong one?
https://www.thirdgen.org/forums/tech...-you-have.html
Old Dec 6, 2015 | 04:15 PM
mdtoren's Avatar
Car: 1986 Iroc Z28
Excellent info in there, some posts seems to suggest you have use the airtex wells unit with an 86+ but others do not, will the 86 ecm be able to use the output signal from the wells unit?
Old Dec 8, 2015 | 07:01 PM
Vader's Avatar
My '86 still has the Wells MAF with no problems. The 1986-UP MAF uses an analog voltage (0-5V) output signal whereas the 1985 unit uses a digital (FM) signal. I've done a few TPI conversions through the years and used the Wells MAF without failure. These are a couple:
Old Dec 9, 2015 | 11:43 AM
mdtoren's Avatar
Car: 1986 Iroc Z28
That's great news! I will start looking other places to solve my current problem then, I was afraid it was the wrong MAF causing it. Thanks again man, I think you have helped me out more than a few times on here!
mustangman65_79
Dec 15, 2015 04:18 PM
Showcase1186
Car Audio
Dec 10, 2015 09:31 AM
yessahbud
Dec 6, 2015 02:56 PM
zero13
Dec 1, 2015 06:33 PM
rusty vango
Dec 1, 2015 12:37 AM
