Fuel problem in-tank?
Old Dec 7, 2015 | 09:22 AM
Bandit400's Avatar
Car: 1992 RS, F41
My original low mileage (70k) 1992 Camaro RS 305 died one day while driving. It would start and barely run for a couple seconds at a time, enough to finally move it over off the road.
The shop tested the fuel back near the tank and said there's no pressure.
If it is supplied fuel at the throttle body it will run.
The fuel pump is working.
They say there are some rubber lines in the tank that are likey deteriorated and thus the pump is not sucking fuel.
So they say to drop the tank and address that and go ahead and replace the aged pump as well.
Sound likely?
Old Dec 7, 2015 | 10:19 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Fuel problem in-tank?
Yep. Lines are deteriorated.
Time to drop tank and replace pump. Get a good pump, AC Delco, Delphi, or Walbro
Old Dec 7, 2015 | 08:03 PM
B4C5.7's Avatar
Car: 1989 IROC G92 LB9 MK6
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Bob's right, time to drop the tank. be sure to clamp the hose on well and use quality hose....you do not want to do this twice.
Old Dec 7, 2015 | 09:18 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Agreed. Dropping the tank is a huge pain in the rear. I did mine this past spring and went with a Granatelli 340lph pump. (#gm-722-340)
Old Dec 8, 2015 | 12:22 AM
Bandit400's Avatar
Car: 1992 RS, F41
Thank you everyone. I appreciate it. Been a long time since I've been on the board.
I hope you guys have a great week!
FormulasOnly
Nov 25, 2015 04:31 PM
Batwill
Nov 13, 2015 09:48 AM
ndndndnd
Nov 13, 2015 07:36 AM
igende
Nov 9, 2015 08:48 AM
spoazzy1
Nov 8, 2015 03:10 PM
