Thermostat question?
Old Dec 10, 2015 | 08:41 PM
jpnc's Avatar
Car: 1988 GMC C1500
Engine: TBI 305
I put a 195 degree thermostat in my 305 engine. It works good but when I shut the engine off it goes up to 215 degrees. Should I put a 180 in it?
Is 215 degrees too hot?
I live in NC
Old Dec 10, 2015 | 09:00 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Thermostat question?
215 is not too hot. Of course the sensor will heat up right after the engine shuts down because the water isn't circulating anymore.
Old Dec 10, 2015 | 09:01 PM
jpnc's Avatar
Car: 1988 GMC C1500
Engine: TBI 305
Thank you!
Old Dec 10, 2015 | 11:37 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Thermostats restrict flow to bring an engine up to operating temperature and to keep the temperature from going below that during operation. Once it's open, it's open and the temperature is free to climb higher. A thermostat can't keep the engine from getting hotter unless it's stuck closed.
When the engine is running, it's the water pump and rad that have to keep the temperature from going too high.
A pressurized rad cap raises the boiling point of the coolant. Water will boil at 212F when not under pressure. Put it under 15 PSI and it won't boil until around 230F
Decades ago, a 180* thermostat was normal. With newer modern cars, they're designed to run hotter to reduce emissions so they all use a 195 thermostat. Engines running up to 215* is normal.
As mentioned above, shutting the engine off and the temperature increases it's because there is no coolant flow and heat rises to where the temp sensor is. If you start the engine and the temp drops back down then everything is normal.
Old Dec 11, 2015 | 05:47 AM
jpnc's Avatar
Car: 1988 GMC C1500
Engine: TBI 305
AlkyIROC, Thank you for the very detailed information. I'm going to leave the 195 in it.
Old Dec 11, 2015 | 10:19 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
There is a lot of info out here and on the web about running lower temp thermostats and using other methods to help keep the car running at a good temp. You may want to google around and see what people are saying.
Old Dec 11, 2015 | 08:38 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
these cars came with 195* thermostats in them so I'd leave it, as long as its not overheating while driving then you'll be fine.
red88tagta
Car Audio
Jul 5, 2019 09:25 PM
GMan 3MT
Jul 23, 2016 10:39 PM
luvmy64
Dec 11, 2015 07:35 AM
FiVe KiLLZ
Dec 9, 2015 07:40 PM
BDR
LSX and LTX Parts
Dec 4, 2015 11:01 PM
