tpi to carb swap fuel delivery problem
Old Dec 14, 2015 | 12:17 PM
timonator's Avatar
Im trying to help my son with his 86 IROC that he put a carbed 350 in. Originally we set it up with the stock electric fuel pump and regulared return. That worked long enough to break in the cam. When we were running it to adjust the carburetor the electric pump stopped working before we could do anythin.
Old Dec 14, 2015 | 12:20 PM
timonator's Avatar
Re: tpi to carb swap fuel delivery problem
[QUOTE=timonator;5987673]Im trying to help my son with his 86 IROC that he put a carbed 350 in. Originally we set it up with the stock electric fuel pump and regulared return. That worked long enough to break in the cam. When we were running it to adjust the carburetor the electric pump stopped working before we could do anything. We swiched it to a mechanical pump with the same return. It built a little pessure 3-4 lbs then ran out of fuel and would build enough to fill the float bowls, start and run out. Tried a second mechanical pump with the same results. Any ideas ?
LittleFranks
Jan 11, 2016 11:28 AM
colts24ap
Dec 1, 2015 01:05 AM
NiG
Nov 24, 2015 05:30 PM
SHELL929
Nov 18, 2015 01:51 PM
hectre13
Nov 17, 2015 11:31 AM
