1991 camaro rs Air Pump pulley knock
Old Dec 15, 2015 | 12:48 PM
Iblis's Avatar
Hello all,
So basically I was driving along the freeway and noticed my steering wheel became tough to turn as if the car shut off so I figured it was the power steering pump..when I pull over to check under the hood I realize my serpetine belt is missing. Lately I've been hearing a knocking noise and found it to be the pulley on my air pump (checked by hand and it wiggles back and forth pretty bad). My question is do I replace the whole air pump or just tighten the pulley because the new belt keeps jumping off at the air pump. I cant seem to find a new air pump with the pulley or just a pulley by itself. Any suggestions or help welcome.
1991 Camaro rs mpfi 3.1
-Thank you
Old Dec 16, 2015 | 03:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Did you try to tighten the bolts that hold the pulley on?
Old Dec 17, 2015 | 04:37 PM
Iblis's Avatar
Re: 1991 camaro rs Air Pump pulley knock
Got around to taking the pump off to find out the pulley and pump are both warped..instead of three wholes on the pulley its one big one. On the search for parts now
-Thanks for the response
ramicio
Nov 23, 2015 09:53 AM
1982firebird7
Nov 17, 2015 07:03 AM
cel19
Wheels and Tires
Nov 16, 2015 07:22 PM
tpi88camaro
Nov 16, 2015 02:45 PM
