How to properly check oil level?
Old Dec 20, 2015 | 01:33 PM
'91CamaroRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: 4 Speed Automatic
I hope this isn't as stupid as it sounds,so bare with me. On my dipstick it says "operating range." Which to me says to check the oil while the engine is on and warmed up. Am I right? Every other car I've dealt with always had a "cold level" and/or a "hot level."
Old Dec 20, 2015 | 02:11 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: How to properly check oil level?
No,You Never Check It With The Engine Running.
Old Dec 20, 2015 | 02:55 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Are you sure you're looking at the oil dipstick and not the trans fluid dipstick? I've never seen an oil dipstick with "hot" and "cold" on it, but all of the trans fluid dipsticks I've seen have those markings.
Old Dec 20, 2015 | 03:17 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
This is also in the Brakes section?
Old Dec 28, 2015 | 06:53 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Operation Indoctrination
Operating Range refers to the maximum and minimum recommended levels of oil when the engine is warmed up, and the engine is OFF.
Typically for your VIN add one quart if the level is at the bottom of the Operating Range.
Happy Racing !
If You’re In Front Of Me DON’T Slam On Your Brakes Just Because Someone At The Head Of The Pack Is Spinning
Yeager
Jan 1, 2016 06:57 PM
BOOT77
Dec 19, 2015 02:02 PM
Night rider327
Dec 18, 2015 12:42 AM
jpnc
Dec 17, 2015 07:30 PM
'91CamaroRS
Brakes
Dec 14, 2015 01:07 PM
