idle/running problems
Old Jan 18, 2016 | 07:53 PM
ryan thomas's Avatar
Car: 1988 camaro
Engine: tbi 350
Transmission: th700
Axle/Gears: stock
hey
So I have an 88 Camaro that i put a 350 tbi in and it has this strange idle problem. the rpms fluctuate up and down as much as two thousand rpm and at times the engine just idles down so much it dies. I am totally clueless. Any ideas?
Old Jan 20, 2016 | 05:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: idle/running problems
Welcome aboard thirdgen.org.
Did you install a 350 TBI ECM & all, or put a 350 under your LO3 TBI system?
Old Jan 24, 2016 | 02:52 AM
Car: 1988 camaro
Engine: tbi 350
Transmission: th700
Axle/Gears: stock
yah I got the ecm out of a suburban. It turns out it was the throttle position sensor so its fixed now.
thanks
Old Jan 24, 2016 | 02:17 PM
John Hagan's Avatar
Car: 1988 Camaro Iroc-Z
Engine: 350 TBI
How did you fix it? Did you replace the TPS or just readjust it? Not sure if it even is an adjustable TPS.
Old Jan 24, 2016 | 05:05 PM
Car: 1988 camaro
Engine: tbi 350
Transmission: th700
Axle/Gears: stock
I just replaced it completely.
nikom1
Jun 30, 2016 07:12 AM
db057
Dec 24, 2015 07:11 PM
Sean Brereton
Dec 24, 2015 11:24 AM
jorgeblancojr
Dec 23, 2015 10:05 PM
84 1LE
Dec 20, 2015 09:12 PM
