Gear select problem.
Old Jan 28, 2016 | 03:49 AM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
At the moment, I am driving my friends Camaro as I wait for an engine to come in for my car. The problem I am having with his car is this. Park has now became reverse. It will start in Park, but it will move backwards if I don't keep my foot on the brake. It will not start in neutral, but then again neutral may not be neutral anymore. I'm thinking p/n switch and/or linkage under the car.
Old Jan 28, 2016 | 07:12 AM
Re: Gear select problem.
Most likely, the shifter cable.
Old Jan 28, 2016 | 08:05 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Check the bracket fastened with the trans pan bolts.
TKO500
Interior Parts Wanted
Mar 15, 2016 11:25 PM
Zell1luk
Brakes
Jan 14, 2016 12:34 PM
Dinero
Jan 10, 2016 10:40 AM
BadRiggins
Jan 8, 2016 10:55 AM
Eric-86sc
Jan 5, 2016 10:18 AM
