loosening belt from AC
Old Feb 4, 2016 | 11:53 AM
mans1's Avatar
Car: pontiac firebird trans am 1984
Engine: 5.0 v8 H.O
Transmission: auto
Axle/Gears: 700R4 auto overdrive
hi I am having trouble loosening the belt that goes from the AC to power steering then the crank and water pump the other belt that goes from the alt water pump and crank is no probs I've loosened 4 bolts and no movement the AC is above the power steering pump on the drivers side thanks does the ac and power steering pump share a bracket that is stopping the AC unit from moving to loosen the belt
Old Feb 6, 2016 | 11:38 AM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
Re: loosening belt from AC
what I need to know does the AC unit pivot and how many bolts do I have to undue
Old Feb 6, 2016 | 02:55 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Check for bolts on the backside as well....
Old Feb 7, 2016 | 11:33 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
i hate those late 70's/early 80's V belt setups. they put too damn many bolts in there, and there is always one or two hidden ones that come in from the rear of the accessories for some reason that only made sense to someone at GM powertrain in the late 70's.
Old Feb 7, 2016 | 12:13 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Old Feb 10, 2016 | 11:31 AM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
as you all know I have to move the AC unit out of the way but leave the lines connected so I can take the power off and change it and the water pump as well that's the plan
Old Feb 10, 2016 | 09:58 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
IIRC, the four bolts circled in the attachment are the ones that will allow the AC compressor to pivot so you can remove the belt.
It helps to loosen the PS pump and swing it out of the way to get more slack in the AC belt.
1Aauto
Sponsored Vendors
Dec 12, 2016 10:43 AM
tvc 15
Apr 13, 2016 06:29 PM
rubblerubble
Feb 11, 2016 09:48 AM
mans1
Feb 8, 2016 12:20 PM
