Car takes several cranks to start
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Car takes several cranks to start
What is fuel pressure doing?
Does the mere act of lightly pressing the gas make it start on the first attempt?
Car: 1991 Z28 1LE
I would start with what ploegi said and check your fuel pressure for leak down. Any reason you replaced the FPR? When the fuel system primes it should hold that pressure, if the pressure begins dropping then you have a bad pressure regulator or a leaky injector.
I changed the FPR because my car had hydrolocked with gas.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
If I recall correctly on efi; If the engine starts when you tip the throttle in it means that there is too much fuel and you needed to introduce more air. Look into injectors or a bad idle air control valve.
Engine: 4++,350 & 305 CIs
around 1/3 pedal is adding fuel while cranking and to the floor is clear flood mode.
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
what is your starting procedure? it might take that long for the pump to build enough pressure to start it so if you just ramrod the key straight from "off" to "start", it's gonna take a few revolutions to light off...
what happens if you turn the key to "run" and let it prime a few seconds before hitting the key?
Car: 1991 Z28 Vert
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
What is clear flood mode?
Engine: 5.7 TPI
Step hard on the gas while cranking, and the ECM interprets that as "clear flood" and DRAMATICALLY cuts back on how much gas it squirts.
I didn't know that. That's good to know just in case.
rusty vango
Feb 5, 2016 06:52 PM
