cylinder running lean
Old Feb 13, 2016 | 03:01 PM
dm3k's Avatar
Car: 1989 iroc z
Engine: 5.7
One of my cylinders is running lean. Car has 87000 miles on it. Changed my plugs about 800 miles ago. I noticed my passenger side rear plug was in bad shape when I swapped them. Checked the new plug the other day and it looked bad again. Any suggestions?
Old Feb 13, 2016 | 04:12 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: cylinder running lean
Is that from running lean, or is it burnt oil? (ash deposits) how are your valve seals?
Old Feb 13, 2016 | 06:51 PM
OrangeBird's Avatar
Car: 1989 Firebird
You are correct , that cylinder is burning oil . Since it's burning oil , and if it is actually running lean as well , It's highly likely he needs new intake manifold gaskets .
Old Feb 15, 2016 | 08:47 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Nothing there to indicate lean.
Do the easiest first: change valve seals.
If it persists, then do as Orange says....intake gaskets.
nova983
Brakes
Oct 25, 2016 09:58 PM
zracTA
Exterior Parts Wanted
Jan 31, 2016 09:18 PM
kobrak
Jan 24, 2016 08:44 AM
Vanilla Ice
Jan 22, 2016 07:11 AM
florida_gators
Jan 15, 2016 08:36 AM
