Rear Mount Cold side pics.
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Planning a rear mount turbo setup due to wanting to keep all accessories under hood and maintain as stock a look as possible.
Can anybody point me in the direction of or show me how they've routed the cold side piping? I'm not worried about the hotside as that's pretty simple.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Engine: LB9
Axle/Gears: 3.08
Re: Rear Mount Cold side pics.
No real routing picture in there. What I saw said you ran it underneath the entire way then up the front of the motor? I didn't think there was enough clearance for that.
Car: 89 Iroc-z
Transmission: TH400
3 pics in there lol over axle, down the trans tunnel on fuel line side then under kmember
I would advise goin up over kmember instead
Car: 89 Iroc-z
Transmission: TH400
2.50" pipe has plenty of clearance. By the kmember however its low
Engine: LB9
Axle/Gears: 3.08
That's how I read it. I saw the pics but didn't see one where it turned up to the intake.
Thanks for the help!
Engine: LB9
Axle/Gears: 3.08
I haven't spent enough time below a third gen, I consider myself a fourth gen knowledge guy more so. Is there room above the k member to route the pipe?
Car: 89 Iroc-z
Transmission: TH400
Its tight but if you stay with stock manifolds you can route the pipe up over. Tube k would make it alot better
FiVe KiLLZ
Jan 2, 2016 10:08 AM
