Rear springs for more 'rake'
Old Dec 27, 2015 | 03:07 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Anyone got a suggestion on a part # for rear springs that might give the car a wee more rake, be firm, etc ?
I'm not into the lowered fast and furious look. .
-- Joe
Old Dec 28, 2015 | 01:18 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: Rear springs for more 'rake'
I used the Moog replacements for the Iroc. I can't remember the PN though.
275/60 tires in rear and 235/60 in front
Here are a couple of pics of mine
https://www.thirdgen.org/forums/atta...icture-575.jpg
https://www.thirdgen.org/forums/atta...d-dscf3555.jpg
Old Dec 28, 2015 | 11:53 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
What about just adding a spring rubber to your current setup?
Old Dec 30, 2015 | 09:09 AM
Moog CC635
Old Dec 30, 2015 | 09:17 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Moog CC635
Whats the difference between those and the 5665 ?
I saw threads suggesting both.
-- Joe
Old Dec 31, 2015 | 07:22 AM
3rdgenmaro's Avatar
Car: 88 IROC
I believe the CC635 are variable rate versus the linear 5665. But I could be wrong. I have seen threads saying the CC635 (empty hatch) sit higher and other threads say the 5665 are higher.
Found this on another thread:
CC635:
Spring size: Inside Diameter 4.3", Bar Diameter .5", Installed Height 10.25"
Load rating: 518 lbs.
5665:
Spring size: Inside Diameter 4.3", Bar Diameter .485", Installed Height 10"
Load rating: 580 lbs.
So my suggestion of just adding a spring rubber didn't go too well? Or you need new springs anyways?
Old Dec 31, 2015 | 07:51 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
CC635:
5665:
Interesting.
I actually have some 4th gen (98+) isolators which are taller, but my factory WS6 springs are almost rotted and can be compressed by a small child.
It's one of those deals where, I've spent about $22,000 in parts, paint, etc, might as well replace the last few stock items.
-- Joe
Old Dec 31, 2015 | 08:15 AM
3rdgenmaro's Avatar
Car: 88 IROC
You are right there. Might as well get a new set. Maybe just the new springs alone will raise it to what you want.
Old Dec 31, 2015 | 08:32 AM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
I ended up with the CC635s on my car. Unfortunately it's still sitting on jack stands so I'm unsure how much rake it does or doesn't give. I primarily went with them, because in Minnesota, due to freezing\unfreezing, the roads are horse crap with huge cracks, etc. Looking at the springs themselves, it's only the first two coils that are tight, so I'm guessing that will be enough to dampen the bumps without making the rear too loose. Or at least I hope so.
Edit: I lied, it's more than the first couple. Here's a comparison between my old 84 Trans Am springs and the CC635.
Old Dec 31, 2015 | 08:41 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I got a set of stock z28 springs off my car that had a rake look
Old Dec 31, 2015 | 01:28 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I had the same issue a few years ago and I bought a set of new spring isolators from a '98 T/A. It fixed the issue perfectly.
Old Jan 1, 2016 | 12:59 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
This is with the MOOG 5665 rear springs but the 255/60r15 tires in the rear are also 1in taller then the 235/60r15 tires in front.
I like the nice firm ride I get with them and a set of KYB- "Gas A Just" rear shocks.
Linson
Dec 30, 2015 07:27 AM
jokerZ71
Dec 26, 2015 06:27 PM
fire7rescue
Dec 26, 2015 11:11 AM
angelr
Dec 26, 2015 09:59 AM
angelr
Dec 23, 2015 11:12 PM
