what rear end can i put in my 1982 camaro to have posi
Car: 1982 camaro berlinetta
Engine: 5.7 350 swap
Transmission: th350 swap
Axle/Gears: 26 spline 7.5 ring gear
I have a 1982 camaro with a 350 engine and a 350 transmission swap with a 7.5" 26 spline rear end. what 8.5" posi rear end can I put in it with very minor modifications or with no modifications at all thanks in advance
Re: what rear end can i put in my 1982 camaro to have posi
There is no such thing.
No 8½" 10-bolt has provisions for the torque arm.
That's correct. You can not put a 8.5 or any other rear end in your car without major fabrication and modifications. There are after market 12 bolt, 9 inch and Dana 60 rear ends that will bolt in, but you will pay for them. The only bolt in factory rear ends are the '82 to '02 Camaro and Firebird 7.5 and 9 bolt rear ends.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Don't forget you could order a dana44 from gm back in the day, but you wont find one for sale, and if you do it will cost as much as any of the aftermarket options already mentioned
So how can I make it into a posi and will the 7.5" i have affect my driving with my 350 engine and my 350 tanny and would it cut down my power and my take off
You can install a posi carrier, or a locking center section.
No the 7½" will not "cut down" power or take-off.
The gear ratio it has in it, however, might be subject to improvement.
Before you can go any farther with the 7.5 you must find out what gear ratio is in it. If you have a 2.73 or 3.08 then you are going to need a 2 series limited slip differential to work with those gears. If you have a 3.23 to 4.10 gear then you will need a 3 series limited slip differential to work with them. If you are going to keep your 26 spline axles then you need a 26 spline differential, but you can upgrade to later 28 spline axles and differential if you want to add a little strength to it.
There are several limited slip differentials available for this rear end, but most are 3 series only. The Eaton Posi is a very good one, along with the Yukon Dura Grip and Power Trax Grip LS. These are clutch type differentials. The Eaton Truetrac and Torsen are gear type limited slip differentials and also work very well. I recommend that you avoid all Auburn and Eaton Governor Lock differentials. Then there are the locker kits that you can install in your standard differential. The Power Trax Lock Right will replace the 4 gears in your standard differential without removing the differential from the housing. You don't have to reset the backlash or bearing preload with these locker kits, but they are not as smooth in their operation as the other types.
RAYS87TURBO
South Central
Sep 5, 2018 07:27 PM
crazynights
Nov 30, 2015 05:27 PM
joef2002
Nov 15, 2015 12:02 PM
Showcase1186
Nov 9, 2015 09:17 PM
