will my thm200c parts interchange with a th350
Old Dec 23, 2015 | 10:41 PM
angelr's Avatar
Car: 1982 camaro berlinetta
Engine: 5.7 350 swap
Transmission: th350 swap
Axle/Gears: 26 spline 7.5 ring gear
I finally got my hands on a th350 & I want to put it in my car I currently have a thm200c In my car I want to know what parts will I need to do the swap as fast as possible I have a 1982 camaro berlinetta
Old Dec 23, 2015 | 11:12 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: will my thm200c parts interchange with a th350
Overall length is the same so your driveshaft will work.
The face to mount length is 1/4" diff so you can just drill out the trans mount hole in your crossmember and it will work.
You will need a way to hook your torque arm up to the th-350. Be it a tailshaft housing with the bolt holes, or an aftermarket swap kit like what B&M and hurst use to make which has a plate that bolts to the trans via the tail house to case bolts.. Then your torque arm bracket bolts to that plate.
StevenJ153
Mar 6, 2016 09:59 PM
lbdz28
Feb 4, 2016 09:46 PM
crazynights
Nov 30, 2015 05:27 PM
1BADRZ28
Nov 4, 2015 03:33 PM
bbcvelle
Oct 28, 2015 07:09 PM
