Ring Gear ABS tone wheel removal?
Old Dec 14, 2015 | 08:37 PM
84z28355t5WC's Avatar
Car: 1984 Z28
Engine: 355
Transmission: t5 WC
I'm just looking for the best/easiest way to remove the ABS tone wheel from the ring gear. I'm doing a posi swap and I'm having some fitment issues with the tone wheel installed. Thanks for the help.
Old Dec 14, 2015 | 09:32 PM
Re: Ring Gear ABS tone wheel removal?
Wiz wheel, chisel, hammer, ...
Old Dec 15, 2015 | 07:13 AM
big gear head's Avatar
If you need to use the ring again then be very careful when you remove it. I accidentally hit one with a hammer once and put a dent in one of the teeth. The speedometer wouldn't work correctly, the cruise control wouldn't work and it caused some other problems. I had to go back into the rear end and replace it with a new ring.
A brass punch and hammer would probably get it off if you are careful.
Old Dec 17, 2015 | 06:33 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I removed the tone rings from my 4th gen recently, I had to reuse them so I had to be careful.
First, I put the axles in the freezer overnight. Then, I heated the tone rings with a plumbing torch and carefully pressed them straight off with a couple of pry bars. As you could imagine, this procedure requires 3 hands so I recruited wife to hold one of the bars in place against the back of the wheel studs. Removed rings were in perfect condition and was able to press them back on to axles easily.
Old Dec 17, 2015 | 06:39 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
OOOPs! Sorry, I just read that the tone ring is on the ring gear, not the axles.
Old Dec 24, 2015 | 12:30 AM
Irockthedrag's Avatar
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Axle/Gears: 10 bolt torsen diff 3.73
Brass hammer and a few bangs and you should be good to go. Mine came off with one Wack.
RScamaro92ZACH
May 15, 2025 09:10 AM
shake401k
Wheels and Tires
Dec 20, 2015 11:30 AM
ThridGen_RS
Wheels and Tires
Dec 18, 2015 02:21 PM
Foster382
South Central
Dec 14, 2015 08:50 PM
shake401k
Dec 14, 2015 07:41 AM
