Looking to get some XXR 526 wheels. Need help
Old Dec 10, 2015 | 12:31 PM
ThridGen_RS's Avatar
Car: 1992 Z28
Engine: 5.7
Ok so I've been reading for hours about backspcing and offset to the point of total brain meltdown. I'm wanting to get some XXR 526 wheels, but first need to make sure I have everything right. For the fronts I'm getting 18x9 with a +25 offset and 5.98 backspace. So if I understood correctly from what Iveread, I would need a 1" spacer for wheels to fit correctly. For the rear they would be 18x10.5 with +20 offset and 6.54 backspace, so I would need a 1" spacer as well.
Does this sound about right?
Old Dec 10, 2015 | 06:55 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Re: Looking to get some XXR 526 wheels. Need help
I have those wheels. You will need a 1.25" spacer up front and either no spacer on the rear and just have to massage the fender wells, or get a small slip on spacer.
Also, get the larger offset wheels up front. 35mm I believe? This will keep the hub from interfering with installation.
Old Dec 10, 2015 | 07:15 PM
Car: 1991 Firebird
Engine: 3.1L V6
Old Dec 10, 2015 | 11:29 PM
360Iroc's Avatar
Did you get your wheels online or from a local retailer?
Crazy Im researching this exact wheel and got pulled back here from google.
Old Dec 11, 2015 | 08:03 AM
Car: 1992 Z28
Engine: 5.7
Thank you CharcoalBird! So the rear wheels with the specs I gave should be good to go with just a little BFH mod? BTW awesome looking bird
Old Dec 11, 2015 | 10:19 AM
Car: 1991 Firebird
Engine: 3.1L V6
I ordered mine from Next Level Motoring. Nlmotoring.com
Thank you! Yes, I have the 18x10.5 with 20mm offset and am running 295/35/18s.
Old Dec 14, 2015 | 09:38 PM
360Iroc's Avatar
Thanks, just looked them up! Thats a pretty wicked tire on there. KDW2's?
Old Dec 15, 2015 | 11:36 AM
Car: 1991 Firebird
Engine: 3.1L V6
Yes, KDW2's. If you are patient and do some searching you can get tires for a decent price. I made $5 on one of those rear tires brand new.
Old Dec 18, 2015 | 10:37 AM
tjlewis10's Avatar
Do you have any wheel poke? I was looking at these rims but I do not want the top of the wheels to stick out wider than the car fender. Also do you have your lowered any?
Old Dec 18, 2015 | 02:21 PM
Car: 1991 Firebird
Engine: 3.1L V6
No wheel poke, they fit almost perfect. Massage the inner wells a little and you are ready to roll. Car is lowered with springs that claim a 1.75" drop all the way around.
penguinpanda0
Southern California Area
Jan 18, 2016 08:56 PM
JunJun
Dec 16, 2015 10:59 PM
MDIROC87
Dec 16, 2015 12:29 PM
LiquidBlue
Dec 14, 2015 11:57 AM
greasegrenade
Exterior Parts Wanted
Dec 6, 2015 10:55 AM
