4th gen GU6 rear swap wheel fitment
Old Dec 13, 2015 | 03:08 PM
shake401k's Avatar
Car: 1986 Pontiac firebird formula
Engine: 383 sbc
Axle/Gears: 4th gen 3.42 posi
Have a 3rd gen firebird, just upgraded the rear to a 4th gen disc 3.42 posi. i knew this rear was longer from the sticky thread here talking about 10 bolts. however i cant find a "end all" answer for wheel dimensions and fitting the tallest, widest set up i can manage without serious tubbing.
Before the swap i was running 10.5x29.5 firestones on a 15" rim (not sure the offset) with minimal rub. i say minimal but they wouldnt fit at all without a little metal persuasion, also minimal. overall fitment was good.
the caliper to rim clearance on this swap is very small so i know ill be needing to go up a rim size. basically my question is what is the tallest widest tire i can run ? and what is the offset i should be looking at ?
Old Dec 14, 2015 | 07:41 AM
Re: 4th gen GU6 rear swap wheel fitment
I have stock late 90s Vette wheels on my car... 18x10 or thereabouts, w stock Vette size tires, can't recall the exact size. Fit fine w 2" spacers on a 3rd gen rear with no modifications whatsoever. Should fit the same on a 4th gen rear, or require at most a 3/8" spacer (since the 4th gen rear is 1-5/8" wider on each side).
Firm
Wheels and Tires
Nov 13, 2015 07:04 AM
hotrodln
Brakes
17
Oct 31, 2015 07:31 PM
carattini
Oct 29, 2015 02:33 PM
Mr.84TransAmer
Northern California
Oct 29, 2015 01:59 PM
Dkelz313
Wheels and Tires
Oct 28, 2015 08:12 AM
