Tire direction, importance.?
Old Oct 27, 2015 | 03:14 PM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
To keep this post short, I'm going to skip how it happened and just get to the issue. On my old set of rims I have two that have tires that are 255 35s and the other two are 245 35s... The problem is the way they are mounted is that the 245s are on the drivers side and the 255s on the other. I don't like that, question is, will it be a problem to run the directional tires backwards? That's what I'll have to do to have the 245s up front and the 255s in the back. I'll have to switch the back drivers with the front passenger side, leaving two tires with backwards tread. Is it better to leave all the tires facing forward, but with the different size tires on opposite sides of the car, or will it be ok to run two tires backwards so I can match the front two tires and the back two? If that makes sense.
Old Oct 27, 2015 | 04:33 PM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Re: Tire direction, importance.?
Just have the tires swapped from rim to rim to achieve the correct directional pattern, it just doesn't seem right or look right run'n directional tires backward......
Old Oct 27, 2015 | 04:35 PM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
I planned to. But can't anytime soon. So in the mean time ...?
Old Oct 27, 2015 | 07:41 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
It could be that a directional tire is not just the tread but what's under it.
The construction could be associated with the steal and nylon in the tire its self.
My tires are non directional and staggered so if I wanted to I could only rotate from side to side but I don't even do that.
Maybe its old school thinking but once a tires belt has broken in spinning in one direction I don't like spinning it in the other.
Old Oct 27, 2015 | 08:03 PM
mk1431's Avatar
Car: 89GTA Black, Black cloth
Engine: LB9 26,000 miles
Axle/Gears: 3.45 Australian 9 bolt
uhh yea very important from traction in rain ,noise , pulling,safety,heat buildup the tire internal struction was made for a specificdirection soooo tea get it right
Old Oct 27, 2015 | 09:24 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Getting 4 tires dismounted then remounted and balanced should be $60 at any of the non-chain tire shops. The big-name chains like DiscountTire will cost more, and if the tires are low on tread, the chains won't do it at all.
Old Oct 27, 2015 | 11:51 PM
Dkelz313's Avatar
Car: 1992 Camaro
Engine: 5.0
Ok, I'll just put them on all facing forward then. I'll get Them swapped asap tho. Thanks for the replies.
Old Oct 28, 2015 | 08:12 AM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
what he said. i would only ride like that from your house to the shop.
KarlJ
Nov 13, 2015 09:48 AM
ZMWojnar
Interior Parts Wanted
Sep 24, 2015 08:34 PM
Abubaca
Car Audio
Sep 24, 2015 02:33 AM
89 formula TPI
Sep 8, 2015 08:00 PM
Ironhead38
Sep 7, 2015 02:26 PM
