4th gen GU6 rear swap wheel fitment
Old Dec 13, 2015 | 03:36 PM
shake401k's Avatar
Car: 1986 Pontiac firebird formula
Engine: 383 sbc
Axle/Gears: 4th gen 3.42 posi
Have a 3rd gen firebird, just upgraded the rear to a 4th gen disc 3.42 posi. i knew this rear was longer from the sticky thread here talking about 10 bolts. however i cant find a "end all" answer for wheel dimensions and fitting the tallest, widest set up i can manage without serious tubbing.
Before the swap i was running 10.5x29.5 firestones on a 15" rim (not sure the offset) with minimal rub. i say minimal but they wouldnt fit at all without a little metal persuasion, also minimal. overall fitment was good.
the caliper to rim clearance on this swap is very small so i know ill be needing to go up a rim size. basically my question is what is the tallest widest tire i can run ? and what is the offset i should be looking at ?
Old Dec 19, 2015 | 08:55 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: 4th gen GU6 rear swap wheel fitment
You can run the same tires as before, just order new wheels with more backspacing. I forget if the later axle is 1.5" wider per side, or 2", so measure both your axles, half the difference is your extra backspacing
Old Dec 20, 2015 | 11:30 AM
shake401k's Avatar
Engine: 383 sbc
Thank You ! i will be ordering soon, i can always return the wheel package if fit is slightly off.
Firm
Wheels and Tires
Nov 13, 2015 07:04 AM
hotrodln
Brakes
17
Oct 31, 2015 07:31 PM
carattini
Oct 29, 2015 02:33 PM
Mr.84TransAmer
Northern California
Oct 29, 2015 01:59 PM
Dkelz313
Wheels and Tires
Oct 28, 2015 08:12 AM
