missig,cant find problem
Old Feb 16, 2016 | 03:21 PM
rats85z28's Avatar
hi I have a 85 z28 with tpi, all injectors are firing, got spark,no lifter noises but feels like its missing, new cap rotor,wires,plugs,coolant fan sensor,new injector,intake pleneum gaskets,temp gauge sensor,and ignition modual
Old Feb 16, 2016 | 04:05 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: missig,cant find problem
Cylinder balance test.
Disable one cylinder at a time. (either by pulling the plug wire, or, the injector connector.) Note the RPM drop on each cylinder. (they should all be the same) If you find a cylinder that has little affect on RPM, there's your culprit. If everything looks good on fuel/spark side, time to do a compression test.
Old Feb 17, 2016 | 11:31 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
I'd also ohm test the injectors
Old Feb 17, 2016 | 02:46 PM
mrestrictrplate's Avatar
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
Even though you have new wires one could be bad or burnt. I prefer the assembled wires vs the ones you have to cut and crimp for this reason. I've run across many new bad or nearly new wires. I use plug wire boots which are less than $10 on ebay vs $75
Old Feb 18, 2016 | 03:35 PM
rats85z28's Avatar
ok I have all prefit msd wires,cap,rotor,coil, the number one cylinder is the bad one, new injector, tested wire for spark with a new and exsiting plug, all good I guess is it possible fuel is not getting to the number one injector and maybe a compression test, also I did notice a no fuel present at the number one injector when I changed it too
tpiroc
Apr 24, 2016 10:53 PM
anesthes
Feb 21, 2016 08:20 AM
Night rider327
Feb 16, 2016 12:01 AM
nuggie
Feb 12, 2016 08:02 PM
neilcase
Feb 12, 2016 03:39 PM
