No Start, Cranks, Good fuel (Floods) and spark
Old Feb 19, 2016 | 10:44 PM
Goepfed3054's Avatar
I have a 1985 Camaro with a tpi. i was driving and car shut off instantly. no sputter. someone told me fuel pressure regulator because the motor flooded and got into my oil. changed the fpr and oil = no differece. gave it a new coil, plugs and wires. unplugged ecm and MAF sensor. Charged battery, plugged it all back in except MAF sensor. Started up with some throttle. idle jumped around, then it died. i started it again and eventually it idled by itself. so i plugged MAF sensor back in. tried to give it some gas and she fell right on her face and died. no i cant get her to start again. just cranks and re-floods itself.
Old Feb 21, 2016 | 10:37 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: No Start, Cranks, Good fuel (Floods) and spark
I would try the ignition control module inside the distributor. When those are bad they tend to shut off or act wildly when warm. Allow them to cool and they work for a short duration before crapping out again. When they are going bad they cause intermittent sputter and stall akin to a loose ground in the ignition system. Check the grounds at the back of the cylinder head to ensure they are still tight and the wires are ok.
EDIT: yes a parts store can check the ignition control module but I have seen the tester give so many false positives that I just don't trust it anymore.
KW1985Z28
Members Camaros
19
Oct 16, 2016 06:15 PM
MSgt Luttrell
Feb 4, 2016 08:52 AM
85@IRocZ
Jan 30, 2016 06:52 AM
tonys91rs
Jan 27, 2016 07:18 AM
Ce84q8
Jan 22, 2016 09:47 AM
