injectors
Old Feb 21, 2016 | 07:03 PM
rats85z28's Avatar
injectors
im am right on the 85 tpi model Camaro they are batch fired, if so if you have a bad wire plug you should be able to use the wire next to it to test the injector or wiring on that bad injector? if the wiring is bad can it be jumped off the closest one on the same bank ,bank fired of course
Old Feb 21, 2016 | 07:37 PM
Re: injectors
Yes you can exchange 2 neighboring injector wires, as a troubleshooting technique (and a good one too I might add) to see if a problem moves or stays in place. Then once you've used that technique to locate the defect, you could then ACTUALLY REPAIR it.
Not sure how "jumped" would be A Good Idea in the long run. Sounds kinda like a hack job to me, somehow. I'd personally direct myself more towards "identify" and "repair" as opposed to "jump". But that's just me; maybe your standards are lower? I don't think so, but just throwing that out there, for comparison's sake.
Old Feb 22, 2016 | 08:43 AM
rats85z28's Avatar
Re: injectors
ould love to fix it right I located the none functioning injector just want to find out how to fix it
ev305tpi
Feb 4, 2016 08:40 PM
Drone358
Feb 4, 2016 01:22 PM
Gunner242
Jan 30, 2016 10:42 AM
Crossfiresuck
Jan 28, 2016 08:13 PM
R3500
Jan 24, 2016 07:50 AM
