Two matters of opinion needed~
Old Mar 2, 2016 | 10:38 PM
stephenscamaro's Avatar
Car: 1988 Camaro
Engine: 2.8 to 383
Specs:
88 camaro
383
700r4
street/strip
86+ block
aluminum heads
no stall
1) New intake, the Edelbrock 2701 performer EPS. Good, bad or the ugly?
2) Port matching? Will I see gains that are worth the effort?
Old Mar 3, 2016 | 01:12 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: Two matters of opinion needed~
What compression, cam, and more detail on the heads?
The 2701 is just a tick better than the performer and the performer is just a hair better than stock.
The performer RPM is the gold standard for street/strip sbc intakes IMHO.
383 can move a lot of air and I feel if the cam and heads are anything more than stock the performer eps will be a bottle neck and choke the power
Old Mar 3, 2016 | 08:13 AM
Car: 1988 Camaro
Engine: 2.8 to 383
64cc/205cc heads, 10.3/1 CR and no cam yet. Considering the ***** Thumpr but not final yet, I need to match all m components first before I purchase a cam. This is what I am doing.
Performer RPM or the AirGap a better choice?
Remember, this is a street engine with MAX RPM at 5500/6000
Old Mar 3, 2016 | 10:35 AM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
RPM Air Gap is really the cream of the crop as far as street cars go, even if you're maxing at 6000 RPM. I wouldn't recommend a ***** Thumpr. They sound cool, if you like the massive lopey idle, but that's about it. You'd be leaving a lot of power on the table, in my opinion.
Do you have springs on the heads yet? What's your limitation in lift?
Flat tappet or roller?
Old Mar 3, 2016 | 12:02 PM
Car: 1988 Camaro
Engine: 2.8 to 383
Max Lift: .550"
Coil Bind: .740"
Intake Install: 130lbs @ 1.8
Exhaust Install: 130lbs @ 1.8
Closed Sear Pressure: 110lbs
Open Seat Pressure: 300lbs
Outside Diameter of Outer Spring (in): 1.450 in. Damper Spring Included: Yes
Number of Springs Per Valve: Dual
Flat tappet
edixon24
Nov 8, 2016 08:34 PM
AM91Camaro_RS
Feb 19, 2016 09:59 PM
66_C10_TPI
Feb 16, 2016 04:24 PM
Phirewire
Feb 15, 2016 10:08 AM
hectre13
Feb 8, 2016 09:28 AM
