Alternator pulley bolt. Reverse or normal threads?
Old Mar 4, 2016 | 03:52 PM
Abubaca's Avatar
Are the threads reversed or normal. I'd think they're reverse so they don't self loosen. Of course, if installed properly, it may never come off, so maybe they're normal. If you google this, there are countless threads suggesting it's either one OR the other. ...car is an 89. ...not quite enough threads showing to see.
Old Mar 4, 2016 | 06:16 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Alternator pulley bolt. Reverse or normal threads?
normal thread.
Old Mar 4, 2016 | 07:44 PM
Night rider327's Avatar
Car: 1988 Camaro
Std. threads, clockwise tighten, counterclockwise to loosen
Old Mar 5, 2016 | 02:48 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Might have to use an impact gun when dealing with a pulley.
I usually try to break pulley bolts loose using the tension from the belt but that's mostly useless so I take it to a shop or rent an electric impact gun from a auto parts store.
Or there's this = http://www.harborfreight.com/12-in-h...nch-68099.html
Old Mar 5, 2016 | 08:50 AM
Abubaca's Avatar
Thanks guys!
1MeanZ
Third Gen Expo
38
May 19, 2017 11:17 PM
maroe624
Mar 11, 2016 08:20 PM
gladback007
Feb 28, 2016 04:05 PM
closer
Feb 24, 2016 07:49 AM
Abubaca
Feb 23, 2016 09:23 AM
