Pushrod Length, checker springs, and valve lash ???
Old Mar 13, 2016 | 04:18 PM
Abubaca's Avatar
soooo, I'm measuring for pushrod length. Got my adjustable pushrod, light weight checker springs, my sharpie, and it took a few tries, but I got a nice thin mark, right down the center! However...I noticed that when I set the valve lash, the valves are opening ever so slightly when I give it the extra "1/2" turn past zero lash. Now, my guess is that this is strictly due to the check springs being soft, AND....regardless....the geometry of the rocker arm still isn't changing, so the length SHOULD be good to go. Right?
...does this all make sense? Am I good to go?
Old Mar 13, 2016 | 04:46 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: Pushrod Length, checker springs, and valve lash ???
Yes, when you get the valvetrain to zero lash, and then give it that 1/2 turn, it will open the valve slightly until the hydraulic lifter takes time to compress.
You're OK.
Old Mar 13, 2016 | 05:06 PM
Abubaca's Avatar
sweet. thanks.
Old Mar 19, 2016 | 02:29 AM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Sometimes i think owners try and make to much science out of the rocker arm/vlv tip pattern. No matter which way u do it u want a contact patch centered over the middle 1/3 of the vlv tip. And u want to check your rocker for clearance on the spring retainer and the stud itself.
Best geometry is to have the centerline of rocker arm 90 degrees to the vlv stem at 50% lobe lift. But that can be painful w/o good tools. Myself i use the "checker tool" from ProForm or Manley. Gets the job done in minutes - not hours. But then i run modest lift cams.
notrabies
May 16, 2016 09:50 PM
bamaboy0323
Mar 22, 2016 09:40 PM
rgauder
Mar 13, 2016 04:34 PM
91TAFBWS6
Mar 13, 2016 02:00 PM
SRKLEGIN
Mar 7, 2016 06:40 PM
