Camaro will crank but not turn over
Yesterday i had issues with my ignition coil, got that replaced, had my icm checked and came back good, cleaned the distributor and got a new rotor for it. After a 10hr drive and letting it sit overnight i have had no issues. i go to my car to start this morning and it will crank but not turn over. Anyone got any ideas?
87 2.8 v6 camaro
87 2.8 v6 camaro
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: Camaro will crank but not turn over
cranking IS turning over.
You mean it turns over, but does not fire?
Replace the module.
"Check" is notoriously unreliable. ESPECIALLY when it comes back "good". THIMK: it fails when it's hot, and works when cold (maybe); when you "check" it, it's cold for sure, and it works (maybe); what does that tell you about what it's going to do when hot? Or even, next time, when it's cold? Right: ABSOLUTELY NOTHING.
Replace the module.
