Is this normal? compressor and fan operation. (Video)
Old Mar 16, 2016 | 12:48 PM
BOTTLEDZ28's Avatar
Transmission: A4
This is what the A/C compressor does as soon as the car is started. Within 5 minutes, the passenger cooling fan will also turn on for a second or two and then shut off. Problem with that is the engine temp was under 200 degrees.
http://vid3.photobucket.com/albums/y...pshydwfvsp.mp4
Old Mar 16, 2016 | 12:52 PM
BOTTLEDZ28's Avatar
Transmission: A4
Re: Is this normal? compressor and fan operation. (Video)
Here is a video of the gauges with the engine revved up slightly (washer in the TB). Notice the engine temp??
http://vid3.photobucket.com/albums/y...psmgjmntsf.mp4
Also notice how the cycling of the compressor causes the RPMs to dropped. Yes, I know this will happen since its creating a drag on the engine but my question is, should the compressor be cycling like that at that engine temp? A/C seems to blow cold air BUT it was 35 degrees out.
Old Mar 16, 2016 | 01:01 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Second fan will operate with the AC on. As far as the cycling goes, it's low on freon. It should stay on longer than that during a normal "cycle." It's protected by a low pressure switch so it shuts down so you don't run the AC with low refrigerant.
Old Mar 16, 2016 | 01:20 PM
BOTTLEDZ28's Avatar
Transmission: A4
Is the passenger side fan the "second" fan?
Old Mar 16, 2016 | 01:33 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Yes, it would normally come on around 238-239* ish and when the air is on.
Disclaimer...........USUALLY ON A NORMAL, STOCK, UNMOLESTED, AND NORMAL OPERATING CAR.
That is when my car's 2 fan comes on.
Old Mar 16, 2016 | 02:51 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I haven't studied this system in a long time and alot of cars ago, my 87 is AC delete and the fan control completely redesigned. So my memory on this particular system is questionable, short of reading the manual again.
But in general, the second fan is the high temp and the condenser fan so it runs above 230-240 degrees and whenever the compressor is on. As far as the compressor cycling, that can be low charge, or it can be caused by running the defrost when the engine and ambient air are cold. In AC speak, temperature equals pressure. Cold ambient temps cause the pressures to run low. The compressor, and condenser fan are controlled by the low pressure cycling switch which turns the compressor on at about 50psi and off at about 25 psi. On a cold morning, it doesn't take long for the compressor to pull the low side down to 25 psi.
Have the system pressures and temperatures checked when the weather gets warmer. You may need to have it recharged. If it is low, a leak test would be good. Make sure they add leak tracer dye to the oil.
bryan623
Apr 13, 2016 11:31 PM
kleetis
Mar 14, 2016 07:10 AM
Relik
Mar 11, 2016 03:06 PM
marz1129
Mar 10, 2016 04:34 PM
jim mcgrew
Mar 9, 2016 08:49 PM
