Clutch going?
Old Mar 19, 2016 | 10:51 PM
mclenty0's Avatar
Clutch going?
My car has a weird rattling and im starting to think its the clutch. While im driving it will rattle pretty loud from what sounds like directly underneath the shifter. You cant hear it from inside but if u have the window down it is very noticable. I just laid down underneath the car to listen to it while it was running and sounded like it was coming from underneath the shifter. While driving it rattles and sometimes while idling it is really loud but as soon as i put the clutch in to shift gears it goes away.
Old Mar 20, 2016 | 06:50 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: Clutch going?
What you are describing as a rattle, I call a knock.
If it goes away when you push the clutch in, it's your throw out bearing. The noise you are hearing is the slop in it which is generally louder at idle.
So yes, more than likely you need a clutch too.
TeddyOfTorment
Mar 18, 2016 09:42 PM
Carly_Nikole
Mar 5, 2016 12:46 PM
'91CamaroRS
Feb 29, 2016 12:32 AM
edwardk12687
Feb 21, 2016 05:20 PM
zygee
Feb 19, 2016 09:19 PM
